HELP Audi 90 window problems
Old May 13, 2008 | 07:40 PM
coreym's Avatar
Default HELP Audi 90 window problems
I have a 1995 Audi 90 and my windows switches dont work. I check all of my fuses and they're all good. Do you think its a relay switch? please help
thank you
Old May 14, 2008 | 06:36 PM
viyamate's Avatar
Default RE: HELP Audi 90 window problems
hey that happen on my car sometimes and its the relay try that it should work.
Old May 16, 2008 | 11:28 AM
Audititagain's Avatar
i have same car and on occassion the driver side door controls do something and i hit the window lock and they work again. also, i have ignition switch problem that affects windows. so you can try jiggling the key and maybe it work. good luck.
Old May 23, 2008 | 08:29 PM
Asphalt Unlimited's Avatar
If none of your windows work it's your Window Control Unit/Relay. It's a weird double sided relay, should be part # 443 959 257A or 257B. These are expensive from the dealer but cheap from a junkyard. Now like the problem i've had with mine is that none of the DRIVER's door switches work, in that cause it is actually all of the switches. The drivers door is more seceptible to weathering and coffee spillage and the sort. if you want a quick fix in this case just switch out the back two with the front two on the driver's door and you can operate both front windows until you can get new switches. Any questions feel free to ask. Good Luck
-Shaun
h4x0r
Dec 31, 2011 12:20 PM
jackieviolet
Jun 7, 2011 11:05 PM
goodh20
Sep 5, 2009 04:48 PM
CamGriffin
Jul 4, 2006 04:42 PM
auDi1.8TQ
May 15, 2005 05:04 AM
