Go Back  AudiForums.com > Audi Models > All Other Audi Models
 Idle problems and won't restart after stall >
Old 11-10-2005, 02:16 PM
csr
csr is offline
Default Idle problems and won't restart after stall
Hi,
I've been having an on-going battle with my 1990 2.3L normally-aspirated 100.
The first symptom was a low idle when engine warm. After about 15 minutes of driving, engine would try to idle around 400 and subsequently stall at every stopsign. Tried cleaning out the ISV...no change.
Noticed that the Multi-Function T Sensor wasn't working (dash gauge showing 0) so I replaced that. The dash gauge now works.
Now, the low idle still happens (but rarely) but a new symptom has been added... when cold, the engine surges, idle going up and down for the first 5 min of driving.
3rd symptom--and this is the most frustrating--if the car is warmed up, and I forget to hold the revs up manually while at a stoplight... it may stall, and once it does it absolutely WILL NOT start unless I let it sit for about 15 minutes. It cranks, but seems to not want to catch. After 15 minutes of not trying, I can start it with little difficulty at all.
The funky idle problems / occaisional surging might point to a defective ISV... but this last thing--not being able to restart after a stall...I just don't get it.
Anyone have any ideas?
(thanks in advance)
Old 11-10-2005, 04:27 PM
Default RE: Idle problems and won't restart after stall
MAF sensor
Old 11-10-2005, 09:17 PM
also check the seal on the dip stick it effects pressure loss in the engine hence loss of idle or start up.
[IMG]local://upfiles/12092/F7420AC7604746689E50DC2CA73EF98B.jpg[/IMG]
Old 11-10-2005, 10:20 PM
I think that you have a big vacuum leak somewhere! I had a similar problem on my 1991 100Q a hard start and idle so low that I had to keep my foot on the gas and brake when stoped! When I checked under the hood I found not one, not two, but three hoses that have worked loose. Check for loose hoses, bellows between the mass air flow sensor and manifold, especially pay attention to the plastic/nylon hoses they have a tendency to break. Rubber ones just disintegrate and if you still have any covered with cloth get rid of them.
Old 11-11-2005, 03:47 PM
csr
csr is offline
Thanks for the ideas... I haven't seen any obvious leaking hoses, but I'll have to do a little more hunting around. If it were a vacuum leak, wouldn't it be more consistent though? The low idle condition only happens when the engine is warm, and even then not everyday. Last night when I was driving the idle was consistently hight at around 1200. This morning it was surging up and down.
Left foot braking does get tiring sometimes, lol.
Can anyone describe where the MAF sensor is on this engine? I couldn't seem to find it in the book i have (my book is actually for a 5K, but much of the stuff is the same).
Old 11-11-2005, 07:01 PM
VAF sensor on your car sorry mate
[IMG]local://upfiles/12092/6AF95749113E437E82831534D706488A.jpg[/IMG]
[IMG]local://upfiles/12092/2EEB8563567A42488B76E273EB237E53.jpg[/IMG]
Old 11-11-2005, 07:06 PM
don't know if you can read that, if not I could use macro to take a picture
Old 11-11-2005, 07:23 PM
just thought to try macro out
[IMG]local://upfiles/12092/F5801F00F35A4647AA5C2A56D3F9BDDC.jpg[/IMG]
[IMG]local://upfiles/12092/2336F70CB98144E2AC77BB0D91DB41AC.jpg[/IMG]
Old 11-11-2005, 07:28 PM
mucho better im getting there, new to camera
Old 11-11-2005, 10:52 PM
Interesting looking manual doesn’t look anything like my US R. Bentley!
Quick Reply: Idle problems and won't restart after stall
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
