Low oil pressure above 2400 RPM - 96 Cabriolet
Hello,
My 96 Cabriolet has the low oil pressure light flashing when ever I get it over 2400RPM. When it goes back below 2400RPM, it turns off.
Everything runs OK and sounds fine.
I checked the oil and it was in the middle of the dip stick so I topped it off. This didn't help.
I had theengine flushed and that didn't help.
My next stop is my local mechanic (I'm guessing a bad sensor).
I was just wondering if there was anything else I could do before I start feeding my mechanic.
Thanks,
Marc
Thanks,
Marc
RE: Low oil pressure above 2400 RPM - 96 Cabriolet
If you have not resolved the problem, check out this post (and if you solved it have please post the solution - thats why this is here!!):
https://www.audiforums.com/m_676363/tm.htm
It could be that the brushes in the alternator are marginal and it is a low voltage anomoly. In my case, there were random flashes of oil pressure and temperature lights.
Check out the post ... in my case it was a bosch alternator and the brushes are integral to the voltage regulator which was available at < $80 us. The alternator is ~$200.
Also, in my case the alternator had been replace 6 years ago and was in pretty good shape. If it were original, I would just replace the alternator instead of just the voltage regulator.
tesnii
06-21-2012 05:24 AM
cruciform
04-20-2010 09:38 AM
96A4Owner
03-17-2008 03:06 PM
