Need signal & light stalks
Good afternoon everyone...I have a "89" 80 quattro seems my headlight switch in the stalk is gone as it will not turn on the headlights unless it is held firmly in place and the same goes for high beams to. Hoping someone here has a stalk set for an 80 or 90 from 88-90 that I could get ahold of. Otherwise I need to check local wrecking yards for one. Figured I'd start here, as I've always recieved grweat advice or help before. ANy and all help is appreciated!.......
Check with Force Five in Concord NH -- They have new and used Audi parts at a good price. You'll have to remove the stearing wheel to get at the switch assembly.
If your lucky they will send you the one from my old 200QT!! |
Turn signals will need a amber lens on the signaling light.They can be purchased and mounted to a fiberglass fairing and must have a ground wire attached from the light housing to ground on the car (part of the frame or stock connector for the ground connection).
_____________ Rueckfahrsystem |
