oil pan gasket for 90 quattro
i am needing to replace the gasket and was hoping some1 could give a step by step to make sure that i am doing this right. thanks a bunch
RE: oil pan gasket for 90 quattro
On my 1991 100Q with 2.3L it was a pain in the @$$! If you have leaks I would double check to make sure that it is not something else that is causing the problem. Often what happens is a leak develops in an odd place and migrates along various difficult to see ridges and flanges. A good cleaning with engine degreaser and a pressure washer should do the trick.
thanks for the advice mate!
