Starting 1993 90cs
Hey peeps i have had my audi sitting for about 2 weeks due to me putting a whole new front suspension. but thats not the problem i tried to jump start the car 2 days ago and it was cranking fine BUTT.... it did not start due to my stupidity and had no gas in the vehicle. so i went to get sum gas and put it in and now the car doesnt even crank!!!! PLEASE!!!! sumone tell me wats wrong.
RE: Starting 1993 90cs
Maybe its the fuel pump. If you had no gas the fuel pump might sucked air in and that can destroy her. But i think the car shoul crank even if the fuel pump was dead. Are you sure that your battery is ok and that the altenator is fine?
well i push started it and it worked fine and wen i turned it off and went to turn it back on nothin happened all the lights were workin but i didnt crank
the motor did not turn over you mean
Yeah the motor didnt crank like i said i could push start it and it would run fine but if i try to jump it or jus start it reagularly it wont and it only jus started to do this.
sounds like a bad starter
