Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
03 Allroad Problems
Old Nov 8, 2011 | 11:39 PM
Juno's Avatar
Default 03 Allroad Problems
So i just wanna update my problems that i got with my 2003 Audi Allroad 2.7T.
Right now i have:
1. Suspension Problem (Overnight, the car i going down with the front) plus i got suspension light on all the time for past 6 months.
2. No reverse
3. Blinking lights inside (sometimes)
4. Water on passenger side below the glove compartment, and also on the back matt... (alot of water)
5. Dynamic lights code (Up and down)
I Already changed Timing Belt, Alternator, Fuel Pump, Water Pump, Both front suspension air bags. Not mentioning my MPG (Around 10)
Im totally giving up on that car... Everyday i get in the car to get to work i get new surprise of what is broken. I only did 11k miles on that car...
Anybody can give me any advices, or maybe somebody wanna buy that car?(cheap...?)
Old Nov 12, 2011 | 02:17 PM
swamper8's Avatar
As far as your air suspension goes, if you've had both front bags replaced:
1.) There may be a leak at one of the fittings/lines
2.) you may have a bad air distribution block. (back of vehicle)
If your air suspension light is on then there should be a code stored in the system. You need to get Vagcom or find someone local who has it so you can pull the codes to see what's going on.
No reverse can be a variety of things. VERY common on early TIP AR's. Do a search at quattroworld.com in the AR forum as it's heavily covered online. Could be a bad Trans, could be something as simple as a relay. (odds are you have a problem in the trans though)
Water in the passenger footwell is usually caused by:
1.) water collecting in the area under the wiper cowl, where the battery sits. Check the drain for this area
2.) water leaks down the windshield, under the lower windshield trim, drips into the cabin filter, in the HVAC ducting, out the bottom and into the passenger footwell area. That's what happend to mine. But that's the least of your problems.
You really need to find a local Audi/AR to help you.....or just cut your losses and ditch the car.
Old Nov 29, 2011 | 03:52 PM
kentetsu's Avatar
My mechanic told me that the computers are under the front floors, so if water gets into that area it can be very bad. Guy left his sunroof open, fried his computers, and the insurance totalled the car.
Old Jul 2, 2015 | 05:25 PM
taggart's Avatar
Water in the front foot well is probably caused by the windscreen washer fluid pipes, they often come apart during cold weather, ie freezing temperatures and they also come apart in the rear passenger side wheel well where the air compressor reservoir is
cheers
Old Jul 7, 2015 | 11:32 AM
amiram's Avatar
You can leave the car overnight In height Level 2 And in "Jack Mode" And in the morning you will see which air spring is Leaking. This system Monitors the vehicle's height all the time even if the main switch is turned off And in "Jack Mode" It does not . Regarding the transmission, The transmission computer (TCM) Is Located in the passenger's feet area dry the area well. When the Last time you Replaced the transmission fluid And filter ?
McTyke
Dec 16, 2019 08:42 PM
wmcparla
Nov 23, 2014 09:36 PM
trashinu
Aug 3, 2014 11:24 PM
jenyus
Aug 17, 2012 12:18 AM
McTyke
Mar 21, 2012 12:33 PM
