Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
climate control
Old May 27, 2010 | 02:08 PM
SloRide's Avatar
Default climate control
The air temperature that comes out the vents is always 15-20 degrees warmer then the outside temp. even with the settings on 'low' and after my 1/2 hour drive to and from work. it seems it should purge out any hotter air by then. does the heater always pump out a little? when i had my A6, which at times had no heat i had this thermometer stuck in a vent to keep track of the temp. now the ar has plenty of heat but it seems like it should cut back when it is hot out.
AnthonySlaughter
Aug 3, 2014 07:27 PM
a8audiv8
Apr 13, 2007 05:33 PM
cian_ie
Jan 10, 2007 07:07 PM
02A4
Mar 27, 2005 10:42 AM
