AudiForums.com
-   Allroad Model Line (https://www.audiforums.com/forum/allroad-model-line-47/)
-   -   Considering purchase... Quick quesitons (https://www.audiforums.com/forum/allroad-model-line-47/considering-purchase-quick-quesitons-54056/)
cnews Feb 9, 2007 02:43 PM
I have an XC70 at the moment but fancy an Allroad. I have scanned through a few forums and found a few concerns about the auto box so as I am not really bothered either way have decided on manual. I am in the UK.
Went for a look at a 2002 "51" Allroad last night. It is a 2.7T manual with 65k miles, 3 owners and is in decent condition but is a very basic spec (for an Allroad).
Anyway, a few questions if I may.
1. It went well and seemed great but the brakes were 'soft' and needed a hearty shove to get them to stop quickly. I am assuming this is not normal. Any views? I mentioned it and he said he would "sort it out" before delivery.
2. The rear tyres were low so he said he would put two on - it has P6 Allroad tyres all round. Is there any reason to insist on these or will any right size/rated tyre do?
3. It sat level and rode reasonably well. The ride height was set so that only the bottom green LED was on. I pushed 'up' to go up and the 2nd LED flashed for quite a few seconds. How long should it take to rise from 1 to 2? I then went through to 3 then 4 and it did come up ok but just took a few seconds each time. (Just trying to convince myself there's no leaks anywhere).
4. When rising the height with the 1st LED lit and 2nd LED flashing I had to wait til the 2nd LED went solid before I could then go up again to level three and same again up to 4. I assume this is normal behaviour (for some reason I was expecting you to be able to press 'up up up" one after the other and the ride height sort itself out in going from 1 to 4).
5. I notice in this pic http://www.eagleeyed.com/DSC05139.JPG (from a completely different car on eBay) the ride height indicator has an orange LED lit. I don't recall seeing this being lit on the car I looked at. What is it and how is it switched?
6. Do all UK Allroads come with headlamp washers? I didn't check that close. It had the little square cut-outs in the bumper but I wasn't sure if this was a blanking plate or if it had squirters underneath. Do you just wash the windscreen with the headlamps on to clean the lights?
7. Silliest question of all now. Looking on the web at different cars I see these two pictures http://www.eagleeyed.com/DSC05139.JPG and
http://i16.ebayimg.com/03/i/000/8a/2d/956e_3.JPG both showing the same shot of the centre console. Is it a trick of the light (so to speak) and these consoles are the same size or are they different? One radio is single DIN and the other double DIN and I am struggling to see where the extra space has come from. Is it just the loss of the fold down flap that makes room for the larger unit?
8. Finally, anyone got a view on the performance of manual 2.5TDi 180 vs the 2.7T? The 2.7T went well but I guess will be quite thirsy (my XC70 2.4T gets about 24-25 mpg) so am not sure yet which I fancy. (Heart says 2.7T, heat TDi)
Many many thanks in advance.
C
bertible Feb 17, 2007 11:19 PM
RE: Considering purchase... Quick quesitons
Hi this post was a week ago, not sure if you've gone ahead and bought or not.
I have a 2001, 6 speed 2.7T (and love it)
First brakes, sounds like they need some work, I would not describe mine as "soft"
Tires, I have Dunlops and have read not such great things about the Pirellis. I would say to insist on a good performance touring tire. Only worry will be any effect on AWD or ABS if you mix two new tires with two used ones, or of significantly different rolling diameter.
Ride height changes take 10-15 seconds between each setting so what you describe sounds normal. If you hit the up or down button more than once, you can actually "backload" the memory and it will do more than one jump at a time. If you want to know something really cool, look up the "402 mod" which will allow you to customize the ride height so that level 1 is ultra low, but only if you buy the Vag-Com cable to interface with a laptop.
The orange LED is for something, but is not normally lit. I think it is when you are in "jack" mode (the mode you MUST lock the car in whenever you intend to jack it up, to avoid screwing up the ride height sensors/leveling system.)
Can't tell if al UK cars come with headlight washers, but Canadian ones do. Those little covers do actually pop up, whenever you hit the windshield washers with the lights on. I actually wish you could turn them off, because you go through washer fluid quite quickly.
Regarding the dashboard, mine is like the first one, which is one of the Symphony radios. The other one is gaining the extra space at the bottom (as well as the cover you mentioned up top). On mine, the ashtray is sucked way down and the console surface slopes down below the ashtray quite a bit more than that picture.
The 2.7T rocks, I get about 12.5 Liters per 100 km mixed city highway, about 23-24 mpg (imperial gal). I have heard that the allroad Diesel is a bit weak but we don't get a lot of diesels over here in Canada so I have never driven one.
