Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Turn signal solid, not blinking
Old Dec 7, 2012 | 08:43 AM
vtraudt's Avatar
Default Turn signal solid, not blinking
2002 Allroad, turn signal stay solid, not blinking.
Hazard switch: all blinking
Is there a separate relay for the turn signal and the hazards?
If the hazard relay is used for both, what may cause the turning signal to stay solid/not blink?
If there is a separate turning signal relay? Location? How does it look (most relay have a 3 digit big letter number printed on them: what is it)?
Old Feb 23, 2014 | 08:11 AM
Zardos49's Avatar
Did you ever get an answer............mine does same
Old Feb 23, 2014 | 08:17 AM
vtraudt's Avatar
Turn signal relay is built into the hazard flasher, 2 relays in there.
I replaced the relay, working since.
Note: have know good working (from my 2003 A6) here if you need.
info@regulatorfix.com
Old Feb 25, 2014 | 02:27 AM
Dasher705's Avatar
Yep your flasher switch is bad should only take a few minutes to swap if you buy a replacement. You just have the gently pry the trim panel off and you should be able to pull the switch out of the dash. If your more skilled with your DIY abilities you can replace the relay in the switch or you can swap the flasher relay to the blinker circuit if you don't mind not having your hazards.
LBoogie
Aug 5, 2017 01:53 PM
neekilo
Sep 11, 2013 10:35 PM
dbelcher
Nov 18, 2011 04:18 PM
Hecareth
Dec 15, 2010 12:23 PM
sdaudi
May 23, 2006 11:52 PM
