2033cc AEB stroker build. OEM and performance parts
Old Jan 4, 2018 | 02:09 PM
GrapeBandit's Avatar
Default 2033cc AEB stroker build. OEM and performance parts
92.8mm forged ABA crankshaft $150 SOLD
Pics->https://flic.kr/s/aHskzQpoMP
144mm scat rods w/20mm wrist pins $365 SOLD
Pics->https://flic.kr/s/aHsku4jFrj
83.5mm supertech 8.7:1 stroker pistons $500 SOLD
Pics->https://flic.kr/s/aHskzQp7Hp
AEB block, thousandth(0.001") shaved off top to make sure its true/flat, and over-bored to Supertech specs $250 SOLD
FFE machined intermediate shaft $100 SOLD
Pics->https://flic.kr/s/aHsmaxvU44
Cometic 85mm MLS head gasket $89
https://flic.kr/s/aHskzQoPpM
Clevite rod bearings CB-1821-P $40 SOLD
Clevite main bearings MS-2227AL $30 SOLD
Glyco thrust washers 026 198 421 $14 SOLD
Victor Reinz water pump gasket 026 121 041M $4
Oil filter housing gasket 028 115 441C $2
Thermostat O-Ring 038 121 119B $2
Victor Reinz rear main seal 028103171B $25SOLD
Crankshaft timing gear 027 105 263B $20
INA pilot bearing 056 105 313C $7
https://flic.kr/s/aHsm8JijuA
AEB head, cleaned, pressure tested, new valve stem seals, new bronze valve stem guides, new Supertech Inconel exhaust valves
Although not in the picture, I do have the springs, lifters, cams, and cam caps $550obo
Pics->https://flic.kr/s/aHsmbQcfpq
Continental Contitech timing belt $25
OEM headbolts 058 103 385B $32
Meyle coolant flange 058 121 132 $7
Victor Reinz Cam tensioner gasket kit 058 198 217 $5
Camshaft seal x2 068103085E $14
Intake manifold gasket x4 058 129 717D $6ea
Victor Reinz exhaust manifold gasket 058 253 039L $13
Victor Reinz valve cover gasket kit 058 198 025A $15
Turbo>manifold gasket 06A253039EEC $5
Turbo>downpipe gasket 8D0253115 $5
NGK BKR7E Spark plugs(4) $9
Mann W940/25 oil filter x2 $10ea
Pics->https://flic.kr/s/aHsm8JijuA
Miscellaneous:
(3)M8x1.25 copper nuts w/10mm hex and (3)M10x1.5>M8x1.25 step stud conversion to connect the turbo to down pipe $30 shipped
Pics->
OEM TT carriers(1J0 615 125 A) bead blasted and painted. Not sure what these go for anymore, but I saw ECS sell non-oem
branded ones for $85 each. Also have stock b5 a4 rear carriers that were also bead blasted and painted at that same time
$160 obo for everything SOLD
Pics->https://flic.kr/s/aHskqWEpDc
Victor Reinz head gasket 058 103 383K $35
Pics->https://www.flickr.com/photos/990882.../shares/kTs196
NEW 034 phenolic spacer for AWM $50obo
Pics->
06A ARP head bolts used once $100obo
Pics->https://flic.kr/s/aHsku4bbqu
06A ARP main studs used once $90 obo SOLD
Pica->
New b5 a4 prefacelift smoked side markers $20 shipped
Pics->
New NLS(NothingLeavesStock) block breather adapter 058 AEB $75 shipped obo SOLD
http://nothingleavesstock.com/online...tegory=2903030
Pics->https://flic.kr/s/aHskzKGE2H
New Zeitronix Zt-2 Wideband Datalogging System w/LCD Display $367obo
http://www.zeitronix.com/Products/zt2/zt2.shtml
Pics->https://flic.kr/s/aHsmbKbSff
DBC throttle body 037 133 064F $35
Pics->https://flic.kr/s/aHskzQeV3D
S4 side skirts w/mounting brackets/hardware, and S4 lower door molding/trim $500obo
S4 fog light grills $125obo SOLD
Pics->https://flic.kr/s/aHsku9tZC1
BNIB Trickflow 23003 inline fuel filter $65 shipped obo
https://www.trickflow.com/parts/tfs-23003
Pics->
Any questions, feel free to ask. Thanks for looking.
Old Jan 5, 2018 | 10:08 PM
added:
Pics->
Old Jan 24, 2018 | 02:42 PM
to the top
Old Feb 20, 2018 | 09:54 PM
bump it up
Old Mar 10, 2018 | 05:52 PM
to the top
Old Apr 28, 2019 | 12:29 AM
TreWright78's Avatar
Side Skirt set still available?
GrapeBandit
Jan 24, 2018 02:44 PM
JETSPEED333
Dec 23, 2010 04:41 PM
Andrew149
Aug 28, 2009 07:51 PM
fobyulous
Jun 6, 2007 06:06 PM
gearup
May 13, 2006 05:36 AM
