B5 S4, A6, Allroad - GIAC ECU for 2001-2002 6 Speed-APR ECU for 2000 6 speed-Also hav
Hey guys,
I have had these 3 ECU's for a while and I want to sell them because they are just sitting in my room doing nothing. GIAC Stage 2 M box: Will fit any 2001, 2001.5 or 2002 6 speed S4's or your 2.7t A6 and Allroad 2.7t. It has 3 programs, 93, 91 and Stock that you can switch with the GIAC flash loader, very nice software over all, boost peaks at 18psi and tapers down to 15. It will fit any stock S4, allroad or A6 but the chip will be much better if you have ''piggies'' or upgraded downpipes. I can also guide you a bit on how to mod your S4 to be able to get the most out of this chip. I can code out the rear o2 sensors on this ECU for $30. I would like $130 plus your stock ECU or $350 with out a stock ECU in exchange. APR Stage 1 A box: Will fit any 2000 S4's, it has 93 and 91 Octane programs in it along with stock I believe, it's a very mild tune for any stock S4, boost peaks at 15psi and tapers down to ~12. You can also run this on your Stage 2 S4. I would like $110 plus your stock ECU or $330 with out a stock ECU in exchange. Stage 1 L box Perfect for your automatic S4, boost peaks at 17 and tapers down to ~15, comes with the secondary air injection and rear o2 sensors turned off. I would like $250 with your stock ECU or $400 without a stock ECU in exchange. Let me know if you guys have any questions. Thanks, GWerks. |
whats you got for a stock 2000 a6?
is the stage 1 L box for the automatic also tuned by APR?
Ecu
Do you still got the giac chip for 20012 audi a6 2.7t?
will any fit 2002 automatic allroad 2.7t?
Giac stg 2
do you still have the ecus?
Allroad ecu
Sold, I have a core for you. Where are you, Im in Berkeley CA
Doc 510-556-4333 Quote:
| All times are GMT -4. The time now is 03:04 PM. |
