FS: Schrick Cams, Hi rev valve springs- ADR/AEB Head, lots of parts - $1200
5 Attachment(s)
I am selling off all of the components to a head that I was building for my rabbit. Its all unassembled but all of the parts are there. I bought most of this as a set-up so not exactly sure where everything is. For those that don't know, the ADR core is the same as the AEB core meaning. The ADR was the european 1.8L NA big port head so the same specs as the AEB, it just had different cams from the factory.
If I don't sell it, I'll probably just assemble it install it and sell the aeb head thats on the car. Heres whats included ADR head - empty (also a bit pitted in the exhaust ports, should be polished a bit) Shrick 260 cams - 0301 A1 601-00 with adjustable cam chain sprockets ( i think? they bolt onto the cam see pics) Hi rev valve springs - tectonics i think? intake and exhaust valves - used valve guides - intake side, never replaced, exhaust side new and need to be installed head gasket head bolts 16v manual timing belt tensioner cam chain tensioner seals Freshly sandblasted valve cover Info on the cams can be found here under pn 0301 A1 601-00 http://www.avl-schrick.com/dat/MK/AV...ICK_2008_E.pdf |
still got everything!
Still got this stuff?
can u call me 6318755334
