B5 A4 *PARTING OUT* EXTREMLY CHEAP
Prices do not include shipping
Pics Available upon Request. If you don't see it….Ask, I probably have it. motocrossracermichael@hotmail.com [/align]1996 A4 *79k* miles Engine Tranny -Automatic - $350 Engine 2.8L79k-$750. Throttle Body - $50 Idle Control valve - $30 MAF w/Sensor - $65 [/align]Power Output Stage (POS) - $75 Coil Packs - $30. each Rail w/Injectors - $50 Engine Mounts - $40/Ea Alternators - $50 Power Steering Pump - $40 Brake Booster - $50 Brake Master Cylinder - $50 Brake Fluid Resevoir - $15 Differential - $75 Coolant Resevoir w/sender - $30 Wiper Motor - $30 Wiper Linkage - $40 Washer Spray Nozzles (Main) - $15/Both Washer Spray Nozzles (Headlight) - $40/Ea Washer Fluid Resevoir - $40 Washer Fluid Pump (Main) - $40 Washer Fluid Pump (Head Light) - $40 Shift Linkage (5sp) - $40 Air Filter Box - $40 Air Filter Box Ducts - $20 Fuel Pump - $75 Fuel Sending Unit - $30 Drive Shaft w/Carrier Bearing - $100 Clutch w/Flywheel - $150 Brakes/Suspension ABS Module (P/N 8D0 614 111 B) - $70 Brake Calipers w/Carriers - $40/EA Brake Booster - $25 Brake Master Cylinder - $20 Front Rotors - $15/Ea Rear Rotors - $15/Ea ABS Speed Sensors $40/EA Tie Rod Assys- $40/ea Control Arms $40/ea Differential - $100 Axle Rear - $45/EA Axle Front - $45/EA Rear Knuckles/Knee Assy w/Hubs - $50/Ea Exterior/Body/Lighting Instrument Cluster - $100 Headlights - $60/Ea Corner Markers - $30/Ea Driver's side Mirror Housing (No Glass) - $30 Passenger's side Mirror Housing (No Glass/Snubby) - $30 Euro Plate Trunk - $150 (Black, has some scratches and indents form a bike rack) Hood - $150 Exterior Door Handles - $10/Ea Fender Liners - $20/Ea Rear Bumper Shocks - $40/ea Front Bumper Assy - $150 Front Bumper Shocks - $40/ea Door Weather Stripping all four doors - $20/Ea Rear Tail Lights - $30 Interior/Electrical/Stereo Aftermarket cd player - $50.00 Climate Control - $75 Central Locking Pump (p/n 4A0 862 257 J) - $80 ECU - $75 Cruise Control Module - $30 Pillar Trims A,B,C - $30/ea Trunk Carpet Complete - $50 Interior Carpet - N/A Dash (Black) - $100 Passenger Air Bag - $75 Sunroof Switch Panel w/Lights - $50 Front Driver's Seat Pwr w/Lumbar, - N/A Front Passenger Seat Manual - N/A Rear Seat - N/A Center Console Black (no Armrest cover) - $30 Door Pulls Black (no switches) Good Condition! - $40/Ea Sunvisors - $20/Ea Column Switches/Stalks $30/ea Window Switches - $10/Ea Interior Door Handles Black/Silver Good Condition - $30/Ea Kick Panels - $20/Ea Heater Box Complete w/Heater Core, A/C Evaporator and Fan Motor - $80 Rear Window Deck w/3rd Brake Light - $50 Tilt Steering Assy. w/ignition and Key - $60 Center Heater Vents - $15/Ea Side Vents - $15/Ea Rear Vents - $15/Ea Overhead Grab Handles - $10 Front Seat Belts - $50/Ea Rear Seat Belts - $25/Ea |
RE: B5 A4 *PARTING OUT* EXTREMLY CHEAP
when you say fender liners do you mean the lower valences?? the unpainted black plastic parts?/
Do you have the glass from the driver and passenger side mirrors? Do you know if these would fit on a 98 A4?
Would you possibly have the rear passenger side reading light? If so, how much shipped to 89410?
i need the driver side washer sprayer cap thats on the bumper just below the headkight..your car is silver right?
Interested in power steering pump and hoses. How much to 38506?
i need the horns...how much shipped to 33781?
I am interested in the comfort control module. Is it still available? Will it work in a 99?
looking for passanger side door moldings, thanks
i got dibs on the passenger side molding iff accord96 doesnt take it.
| All times are GMT -4. The time now is 05:24 PM. |
