Complete cluster swap kit
Old Jan 21, 2014 | 01:15 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Default Complete cluster swap kit
Up for sale is a complete prefacelift LCD cluster swap kit. This will fit cars with the large blue and yellow 26 pin instrument cluster plugs.
The kit is modeled after the same hardware I installed in my car. While most of the hard work is done, the signal for the fuel consumption line must be connected and the pin for the outside air temperature must be swapped to the red plug. Other than that, this kit is plug and play!
Install the wiper arm with trip computer controls, install the new cluster, and plug the harness in.
Unfortunately the cluster has an issue with the speedometer. It does not seem to move smoothly and jumps. The socket for the harness plug on the wiper arm is also loose.
The LCD screen works perfectly and does not have any lines. The odometer will have to be reset to allow you to program the proper mileage in. I will provide more details to the buyer.
I have included some spare yellow wire to run to the ECU as well as a grounding cable ready to be attached behind the cluster.
I will provide as much info as I can (if requested) about how to get this installed and working to whoever buys it.
Asking $150 shipped, but I'm open to negotiation.
Note the speedometer not resting correctly.
Old Nov 29, 2014 | 12:31 AM
Bump.
jam511
Jan 21, 2011 12:58 PM
jnunez71
Jun 29, 2009 11:50 PM
paul3141
Nov 12, 2008 05:23 PM
achTTung
May 18, 2008 02:22 PM
bhj0887
Oct 5, 2005 12:13 PM
