Audi A2 1.4 SE ... oil change !?
Hi all, I'm the proud owner of the above, an 01 petrol with 30k miles added.
I know, I know... you must have had this one before! I have been informed that an oil & filter change will require the oil to be sucked out from above. Is this the case or can a garage do it the "normal" way? Kwikfit cannot seem to answer the q over the phone!!
Would appreciate the simple answer.
Phil
Phil
RE: Audi A2 1.4 SE ... oil change !?
Check it under the engine if there are plug that can be removed to be able for you to change oil.If you see a plug,then you can pull it,just be extra carefull not to cling on the cord of the Audi oxygen sensor.
alex5652
11-17-2012 11:37 AM
sollyd25
06-27-2008 01:52 AM
