2008.5 2.0T How to remove engine cover?
Hi Guys,
I've got a 2008.5 A3 with the new 2.0T engine with the chain instead of a belt. How does the engine cover come off? Looks much simpler than the old 2.0T cover but I can't see any screws or attachment points. Does it just pull off? I just want to be able to remove the oil filter, which is blocked by the left lower corner of the cover. Is there anything else I need to know about changing the oil on this? Thanks!! Al |
Thanks!
Thanks! Turns out the cover just pulls off. The attachment points are in the left and right upper corners and the left lower corner, so pulling at those locations one at a time makes it an easy task.
Here is a site that has photos of the cover and the engine, clearly showing the attachment points. http://forums.fourtitude.com/zerothread?id=3829946 |
