2008 A3 Fog Light Lens Replacement
Hello All,
first post here, in need of some help actually..
my 2008 A3 has a broken lens on the drivers side foglight.
Looking for help on how to fix this (how do I do it) and what part do I need - can I just get the lens separately or do I need a whole new housing.
I think Audi dealer parts and labour would be sky high for what to me must be a home fix..
Any help on the above would be welcome.
cheers
cheers
Should be pretty straight forward:
- Remove the fog cover/grill (pops right out but be careful that plastic snaps easily)
- remove the 3 bolts holding the fog light assembly
- disconnect the electrical plug from the assembly
- pull the fog light straight out
- put the new fog light in
- reconnect the electrical connector
- screw the 3 bolts back in
The lens itself is readily available. If you have the standard a3 - it's around 160$ per side... if you have the s-line it's around 50 bucks per side (ECStuning prices).
