245/35/18 45mm offset, work?
I'm think of getting this tire/wheel combo, did some searching and didn't really get a clear answer if this will fit on my car stock.
I know the diamater is the same but will the wheel stick out to far, and will it rub when I turn lock to lock?
I plan on getting the new TT soon and I would like to be able to carrythese wheels over.
Thanks for your help
RE: 245/35/18 45mm offset, work?
2 problems here; rears aregoingto rub, and fronts likely will, using the 245'seven at stock ride height. Also, A3 wheels are a different bolt pattern than TT. I'm not positive that this is the case for the new TT, but you can easiily check.
ok thanks,I think that'll go w/ a 225/40/18 and when/if I get the TT I can just switch the tires. ya the tire rack says that the wheels I want will fit on the new TT. I guess the issue will be tire size which isn't to bad.
capn
11-14-2012 05:34 PM
Mr. Merk
03-04-2008 08:43 PM
