A3 1.9 TDI 110 SE - intermittent cut out
Hi all,
I have a 1997 A3 3-door model, manual box. Now has 237,789 miles on the clock. Has been faultless (other than aircon) and this new problem. I have and intermittent cut-out on driving. Aggravated by a recent trip to the dealers for (aircon) repair work. Sounds like a bad earth (ground). Can occur after traversing speed-humps, or cornering, but often just rolling along the road. Symptoms are: engine cuts, steering goes very heavy (steering pump is not working), oil light comes on (and beeps), car slows quickly - embarrassing on the motorway (freeway). Pull over, hazards on, and turn ignition circuit to check if "glow-plug" light illuminates. This can take several "tries", usually within a minute, it's back, and then it'll re-start, and be fine (until the next time). Can go days without a glitch, and then can kick-up 3 or 4 times in as many miles. If anyone has any pointers where to look, I'd appreciate it. Needless to say dealers have had 3 tries at it, and come up with nothing, no ECU diagnostics or anything. I have already replaced the battery-top fusible link fuse box which carries the 30amp fuses for the glow/pre-heat circuits. This item was faulty - it had badly corroded connectors and fuses, and a cracked casing (dealer visits again!), but may have become so from poor earth that was causing arc-ing, in retrospect. Here's hoping... |
RE: A3 1.9 TDI 110 SE - intermittent cut out
I also have this problem although it happens infrequently currently. I have a 1997 A3 TDI SE with 71k. Fingers crossed you get an answer!
sounds like an engine load problem check the connection to this switch, if switch not fitted check condition of all engine/battery grounding points
[IMG]local://upfiles/12092/79D44667C1A04DABAC1AAC042A6D985F.jpg[/IMG] |
