A3T180cv - Chipped - P1556
What does "17964 or 1556 charge pressure control negative deviation" on the vagcom mean? How can I fix this?
RE: A3T180cv - Chipped - P1556
17964 - Charge Pressure Control: Negative Deviation
Try clearing the code and see if it comes back. |
I changed relay,MAF,N75 and the problem is existis.On my Audi A3 2000 I've lost turbo boost to 5 psi and i cleared the ecu every time.
Have you changed all of your vacuum hoses?
Yes, all had been tested and they do not present problems.
Before "chipped" it did not present this error.
ORIGINAL: Wagnerlgv Yes, all had been tested and they do not present problems. |
I am with this problem 3 months and I nobody find. The car enters in "limp mode" and when I bind and I disconnect it comes back to have pressure.
bind and disconnect, i'm confused. What does that mean exactly?
Excuse me, I want to say when switching off the engine and re-starting it always cures it (until the next time).
