Paul18 |
04-07-2018 06:20 PM |
Audi A3 2006 Windscreen washer not working (tried every other tip)
Hi All
Hope you can help. - I have a Dual Pump for the Front and Rear
- The washer on the rear works perfectly
- Always use screen wash (Ready Mixed)
- Sometimes, the front windscreen washer used to work, however, more frequently than not, 9/10 times it did not respond/work. Most recently, it does not work at all.
I have tried everything: - Checked the water - fine
- Then checked the Fuse (tried 15A, 25A and 30A). Existing fuse is 15A - no change
- Removed nozzles, blew air into tubes - no change
- This suggested the pump may be the problem, so replaced the pump - no change
- Replaced stalk indicator - no change
- Checked the bonnet latch and made sure headlights are on - no change
Not really sure what else it could be.
Any suggestions?
Thank you
Paul
