Audi A3 Tail Light...One Bulb Won't Work!
Annoying problem...one bulb on my drivers side tail light won't work.
This is what I've tried so far: Changed the bulb (tried numerous bulbs) Checked all the fuses Replaced the holder Anyone have ideas as to what I should look at next? |
Did you ever get an answer on this??? I'm having the same problem...
Trace the wire from bulb to fuse & look for damage.
No, I'm still trying to track down the issue. Though, the other day I noticed that when I lock the car the non-working bulb blinks as normal. Does yours work like that as well?
Rear brake light
Any solution to your rear brake light? Im having the same issue. have replaced the bulb- didn’t work. going to clean out entire assembly and connection and see if that helps.
Ill post any progress I make. |
anyone?
Anyone resolve this? Same issue, driver side lights in the hatch won't light. Also one light in the main body housing (think its led cause its built in) doesn't light either. Changed all bulbs. Nada. Anyone have a solution?
| All times are GMT -4. The time now is 08:11 PM. |
