Custom Installed Radar Detectors...
Old Jan 8, 2008 | 09:39 PM
  #21
BearTrap's Avatar
Default RE: Custom Installed Radar Detectors...
ORIGINAL: Chef
There is a rubber boot down where the steering column meets the firewall. That is the best place to come through, IMO.
Cheers!
That's where I went through the firewall, just be aware there is a rubber cover that comes off after unscrewing three bolt covers.
Old Jan 9, 2008 | 12:22 PM
  #22
spencerjw's Avatar
Not to hijack this thread but for those of us in states where we can have detectors and aren't concerned about it getting stolen...anyone have advice on hard-wiring it into the lighting in your roof or something like that?
I had done this with my cheap(er) Cobra in my '04 Passat. I had it wired to the lights so that it was always-on. Only issue is that when I locked or unlocked the doors the car flashes the interior lights causing a break in that always-on connection and turning the unit on and off. not a big deal, but kind of point defeating.
Anyone have advice on hard wiring a window mounted unit?
Old Jan 9, 2008 | 03:36 PM
  #23
AManCalledE's Avatar
I think I remember seeing where somebody had tapped it into the OpenSky fuse.
Old Jan 11, 2008 | 12:50 AM
  #24
BAMF's Avatar
spencer, try www.audidiy.com - there are a few write-ups on hard wiring a radar detector to a 12v lead that is accessible under the sunroof control panel. I'm not sure if it is a constant or switched 12v though. Most of them are for a Valentine V1, but it will apply to any radar detector.
Otherwise, you could always run the wire under the headliner and down the left A-pillar directly to the fuse box. The rear wiper fuse will work fine and is switched (turns on and off with the ignition).
sluggerjd
May 10, 2009 05:36 PM
jakej
Nov 25, 2007 09:43 PM
diablo9861
Mar 12, 2007 01:56 PM
betz470
Jun 1, 2005 03:57 AM
apg96
Mar 7, 2005 08:32 PM
