CV Joint Rec
I have A3 3.2 v6 2006 and I am looking to purchase new axle shafts for both sides. All websites show the wrong CV joint. Any recommendations would be appreciated.
the axle design was upgraded -- but I found the axle for our car :
https://www.fcpeuro.com/products/aud...ag-1k0407272el you can buy that one and then have trouble with the left (i'm not sure yet i'll update tomorrow) here are replacement aftermarket axles, which seem like these should fit with the flanges described below: https://www.rockauto.com/en/catalog/...+assembly,2288 FRONT LEFT And FRONT RIGHT HERI 75972 HERI 75990 - 1 in stock remaining for the front right (not sure if it's correct or not) -- it arrives tomorrow I will let you know. these are the parts for the upgraded axles -- it is called a flange , or a transmission shaft 02M409351M 02E409343D almost positive these are correct... but again, i will let you know. |
Did you have any luck with the CV axle for the 2006 audi a3
