suspension options?
Old 07-26-2018, 05:59 PM
knotcher's Avatar
Default suspension options?
08 Sline A3; 18" TT wheels.
thinking of lowering the car a bit and wondering if others have had success with 18" wheels. i had to go with 10mm spacers to keep them from rubbing, so not sure if lowering is even possible. would love to hear from others on what setups they've used successfully, coilovers or not.
Old 09-11-2018, 12:01 AM
Default Same problem
Just outta curiosity, did your tires scrape over every little bump? I have the same problem, ditched the 17”, got some VW CC 18” and over every bump, they just scrape. Could bad shocks cause this problem as well?
Old 09-11-2018, 07:44 AM
knotcher's Avatar
if i hit a good sized bump i hear a bit of rubbing in the pass rear...otherwise no.
could be fixed with suspension. or you could cut out the fender liner since that is what it's probably rubbing against.
dannyghost
01-06-2010 11:33 AM
J4Audi
08-11-2008 01:15 AM
johnqw
05-22-2008 12:49 PM
huggis
01-18-2008 11:18 PM
peccin
07-04-2005 11:34 AM
Quick Reply: suspension options?
