Electric windows dont work/wont go up (how to fix)
Old Dec 2, 2006 | 05:25 PM
pabloturbo's Avatar
Default Electric windows dont work/wont go up (how to fix)
Hi guys, Just a quick one,
I have just got my first audi today a 99 1.8t.
A great car but just one thing is on the test drive it was raining so i didnt even think to try the windows, And of cause i get home and neither of the windows work ?
Everything else works fine and theres no warning light on any ideas ?
Old Dec 2, 2006 | 05:34 PM
JohnS1's Avatar
Default RE: Electric windows dont work at all
Yeah...check your fuse panel for blown fuse. Possible bad connection also . My assumption is that you have a common fuse or connector for your electric windows.
It also be possible that windows have been exposed to a harsh cleaning chemical that has ruined the rubber guides preventing window gliding movement.
Old Dec 2, 2006 | 05:35 PM
techbod's Avatar
fuses
Old Dec 2, 2006 | 06:51 PM
pabloturbo's Avatar
Cheers guys i shall have look tomorrow just hope it is a fuse.
Old Dec 3, 2006 | 02:41 PM
pabloturbo's Avatar
Ok so i had a look today and the reason they dont work is someone had unpluged them.
After pluging them in i found out that they dont go up and down in a straight line its like its come off the runners,
So when you try and move the window up it gets stuck then comes back down[:@]
wondered if this is common problem and whats the best way to fix ?
Cheers Paul
Old Dec 3, 2006 | 03:17 PM
techbod's Avatar
check all the bolts on the runners are tight, surly all the windows don't do the same thing??
Old Dec 3, 2006 | 03:58 PM
howbigmassive's Avatar
Yeah, its easy to remove the interior door panels and check. There are only 4 screws I believe.
Old Dec 3, 2006 | 05:55 PM
pabloturbo's Avatar
Ok then so after searching around the net i think iv'e found my problem,
This guide is exactly the same problem i have so just gotta get some new clips from audi
http://www.piglet-net.net/tech/cars/a3-window.html
Old Dec 3, 2006 | 09:27 PM
4RINGSROD's Avatar
WOW!! I would have said take it to the dealer and Yell at them its there responsibility.
Old Dec 3, 2006 | 11:47 PM
A3S32's Avatar
Default RE: Electric windows dont work at all (how to fix)
that's crazy... and the dealership didn't tell you about the problem? sounds shady.
