feels like a miss fire - de-throttle then apply throttle
Hello,
I have a slight issue which has been manifesting over the past couple months. The issue is when i pull back on the throttle to change gear or following a car through town and pull back on the throttle then reapply. for instance when you change gear press the clutch decrease the throttle and reapply. I am in no manner driving fast just normal driving conditions. It feels like a miss fire no power for the split second like a small jerk. I have no idea what could be causing this and there are no warning lights on the dash board. Anyone got any suggestions as to what this could be? The car i drive is a 57 plate Audi A3 2l TDI sportback Thanks in advance Best Daniel |
Wow wonderfully active forum, thanks for all the outstanding suggestions and help guys.
Agreed. This forum seems to be pretty dead.
I think I have a similar issue as what you're describing. Jerks at cruising speed (as if you let off the throttle) and also idles poorly (bogs, acceleration suffers and sometimes stalls at idle). I think there is an issue with my throttle body actuator, but I can't be sure. Good luck |
