HELP !!!!!!!!!!! Please !!!!!
So my cars has been making with weird noise every time I go down a hill when I'm not even pressing the gas it also does it when I'm going at a good speed around 40 and I let go of the gas and when the car kinda goes into neutral and it sounds like a hissing crackling noise ?
I think it might be a bearing ? Or my Diverter valve ?
Assuming you have an A3 (since you posted in the A3 section) and assuming you have the 2.0t engine (since you mentioned diverter valve) - a damaged DV could be possible. Usually a bad DV will be followed by power loss and eventually CEL.
Does the car behave strange in anyway?
anyway?
anyway?
Not in any way it's only that noise it's making every time I stop pressing the gas or when I'm going down hill it's even makes it when I'm in parked and I rev the engine up to 4000rpm and when the rev comes down its make the hissing crackling noise
Well I would check the DV first - especially if you still have the original one. They weren't the greatest and most people already had a DV failure by now. Audi/VW have a revised version which holds more boost and lasts longer. Considering it's a relatively cheap and easy part to replace I would start there.
