key fob
can any body help. slight problem with my key fobs. I have two sets of key fobs for my audi a3 2001. one of which i was able to use the button to open and lock the car and the spare that needed programming to the car in order for it to start the motor. Now both keys cant open the car by pressin the buttons and therefor i have to stick it into the lock and open/lock. but then the alarm goes off.
can someone tell me how to fix this without taking it to audi, as it cost ££££. cheers |
RE: key fob
Got this off another site. Worth a try.
Key Fob Programming VW/ Audi/ Seat/ Skoda Remote Control Programming (1997 ON) Procedure 1. Switch Ignition ON and leave key in the ignition. 2. Mechanically lock the vehicle using the Drivers door using a second key 3. Using the remote control press the Unlock button once, and the horn will sound once. 4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed. Note: When performing programming on additional remotes the procedure is exactly the same, except you press the unlock button 2, 3 or 4 times for different remote. For example: If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes. 5. Switch ignition OFF. 6. Remove key from ignition and check for operation. 7. The coding procedure can be repeated up to 4 times for additional remotes. 8. The ignition must be switched OFF between programming each remote control. Worth a try... hope it helps |
RE: key fob
thanks. i will definitly try it out
cheers dude |
