KW V2 Coilovers Review, NOW WITH PIX!!!
woke up, drove to Group 5 here in SD to get my KW Variant 2 Coilovers installed, came in, dropped off the key, came back 4 hours later and man, my Black A3 never looked better. it was lowered by an inch, there's a thumb's width between thetop of the tires to the tire well, perfectly lowered, not too low, not too high. got in, drove it away and right then and there, there was a difference. it was much smoother than the Stock sport suspension, all the minor bumps in the road wasn't as harsh on my spine as it used to. just cruising to work slower than normal, i noticed every car that passed me by looked over and i smile at them back. i haven't turned a crazy fast corner yet cause i haven't had time, but noticed just making a curve on an offramp, the body roll was really decreased. although i did make an accelerated left turn and the car just stuck to the ground and the car didn't lean at all. that's all i have for the review for now, until tomorrow when i start driving it more. i've only drove the A3 for 30 mins total today after the install. i'll keep you guys updated.
now up next, wheels and tires, maybe in two weeks.
[/align][/align][/align]
RE: KW V2 Coilovers Review
ORIGINAL: SlowWagon08
No camera phone? mental picture? anything????
Chef, So you're getting your Koni's, but do you have a good, dentless car to put it in yet?
ORIGINAL: Audinam
haaaa i'm not that technologically advanced yet.
Cheers!
ORIGINAL: quadric
ALERT: Stupid question
What's the difference between coilover and suspension, if there is at all a difference?
ORIGINAL: quadric
So after looking around the internet, I think I have the answer. So a coilover is essentially just suspension but the fact is that the spring and shock are all in one item. Whereas traditional suspension has separate springs and separate shocks. Is that correct?
ORIGINAL: quadric
If i want to lower my A3 with premium paskage (that now has a horrible 3 inch gap) what should i do? i'd like to get around 1 inch gap, is that ok, too much to little? in future i'd be also putting on some 18's, but if i keep the overall wheel diameter the same that should not play too much into the gap.
i'm not looking for racing suspension, just nice lowering and a little less body roll.
coilover installed will run for 1k?
