LEDs done, HIDs done-- thanks for the help...
Here's what I've been working on. LEDs in the headlamps. Also retrofitted HIDs using FK housing. Just need some minor adjustments
Thanks for Beartrap for his instructions and help on installing HIDs
e
e
RE: LEDs done, HIDs done-- thanks for the help...
The lower LEDs has been disconnected. I'll probably be adding it back witha switch so i can still have the option...
The LEDs are really bright, i just happened to finish late last night and has some adjusting to do. I'll try to takea daytime photo.
e
e
ORIGINAL: robertmrome
That looks AWESOME!!
How much did the full setup cost you (not including your time ) if you don't mind me asking??
$50.00+ for HID kit (ballast, igniters,bulbs, etc)
$60.00 for 3 19" LED strip (weatherproof/encased/built in resistors, i ordered 3 for "just in case" and i did have to use the "just in case" led...)
$10.00 heat gun
and the rest are stuff i already have in my garage (glue, pliers, wires, etc...)
e
ORIGINAL: Swaynest
wow that looks great now that we know the cost how much time did it take?
I tried the OVEN thing, but was more successful with a heat gun.
As a matter of fact, couple of mistakes were made that i had to reopen the headlamps 3 times!! But practically, once you have the headlamps open, it only takes a few minutes to fit and secure the LED strip, clean the unit, and then reinstall the Lens. It takes at least a good 10-minutes of just circling round and round the seams between the housing and lens..
I will try to post a HOW_TO- hopefully this weekend..
e
