Misfire on Audi A3 3.2
Hi All,
New to the forum and looking for help. Recently my car has been abit rough when cold and I noticed that the ESP light stayed on. I then noticed the engine light come on. The fault codes I'm getting from VAG-COM are:
Control Module Part Number: 022 906 032 CA
Component and/or Version: MOTRONIC ME7.1.1 5629
Software Coding: 0000172
Work Shop Code: WSC 06435
5 Faults Found:
19598 - Oxygen (Lambda) Sensor B2 S1: Signal Implausibly Lean
P3142 - 008 - Implausible Signal
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal
16689 - Cylinder 5 Misfire Detected
P0305 - 008 - Implausible Signal
16690 - Cylinder 6 Misfire Detected
P0306 - 008 - Implausible Signal
16688 - Cylinder 4 Misfire Detected
P0304 - 008 - Implausible Signal
Can anyone tell me what may be the cause of this issue?
5 Faults Found:
What year is your car? Take it back to the dealer if there is still a warranty. That better not happen to my car or I will switch over to BMW. I almost already did when those cheapasses took away the audi advantage warranty and stop covering breaks and wipers.
Russ Heinrichs
Aug 18, 2021 12:39 PM
A4ENGRSF
Oct 9, 2010 09:49 PM
