Presenting the AWE Tuning Audi A3 2.0T S-FLO Carbon Intake
An intake that unlocks even more from the Audi A3 2.0T. Presenting the AWE Tuning Audi A3 2.0T S-FLO Carbon Intake:
Highlights
The fully enclosed AWE Tuning Audi A3 2.0T S-FLO Carbon Intake is made from high grade 2x2 carbon fiber that mounts directly in the stock locations and mates up to the factory air inlet pipes, perfectly.
The AWE Tuning S-FLO Filter (included in the kit) is the largest that can fit within the airbox to maximize air flow. This increased flow contributes greatly to the max power gains of 9 hp and 14 ft-lbs of torque at the crank.
The combination of the AWE Tuning S-FLO Carbon Intake and included AWE Tuning S-FLO Filter makes for a more aggressive intake note, with a distinctive turbo spool sound.
Using a UV stabilized resin and clear coat on the airbox prevents yellowing that occurs from heat under the hood.
Power. Sophistication. Perfect look. No Check Engine Light - Guaranteed. Fitment - Guaranteed.
Time for that A3 2.0T to breathe a little easier.
Availability
The AWE Tuning Audi A3 2.0T S-FLO Carbon Intake is available via AWE Tuning’s international network of superstar dealers, or from the factory store. Questions? We’re here. 215.658.1670 or performance@awe-tuning.com..
Images
Highlights
- Fully sealed carbon fiber box and filter combination
- Features AWE Tuning S-FLO Filter
- Max gains of 9 hp and 14 ft-lbs of torque at the crank
- Perfect integration with OEM inlet ducting
- Utilizes stock mounting locations
- UV stabilized resin and clear coat prevent yellowing from heat
- Filters are durable, and washable
- Designed, engineered and tested in house at AWE Tuning
- No Check Engine Light - Guaranteed
- Perfect Fitment - Guaranteed
Availability
Images
Andrew/AWE
B8 Models
11-04-2014 06:21 PM
