RIMS: Will A6 18" 5x112 43 offset fit?
RE: RIMS: Will A6 18" 5x112 43 offset fit?
Probably. A 43 mm offset wheel will be 1/2" farther to the outside than stock 56mm offset Ronal wheels. Using 224/45-18s might just clear if you're not lowered, and you may have to remove the fender liner screw at 12:00 in the front.
You can alsoinstall 'crash bolts' on the front struts to add a degree or so of negative camber that will give a little bit more clearance. Crash bolts will likely give you better turn-in and more front 'stick', but at the expense of tire wear and a tendency to rotate under drop-throttle in a corner (power-off oversteer). Unless you're an autocrosser, I'd avoid that.
Like I said, if you're not lowered you'll be OK. I have 18X8s also, but with 45mm offset, so I'm not that far off. No rubbing, but they likely would if I dropped the car a couple inches.
Smurftastic
07-08-2011 08:14 PM
Funjohnson
9
07-25-2008 07:38 PM
audiboy429
03-23-2008 02:36 PM
chillios
01-14-2008 12:05 AM
