s-line grill badge fitting.
Hi
Just purchased a 2009 a3 s-line tdi and have bought a s-line grill badge from eBay. The grill badge has two bolts on the back with a plate and nut on each bolt. Do I have to remove the grill to fit the badge? Thanks in advance. |
if you open the hood, you can take off the trim that's on top of the grill. just pop off the three connector screws. (i think it's three). then you'll have access to behind the grill/in front of the intercooler. should give you enough space to work with.
good luck! |
