Turbo not kicking in
hi,
I have a 2001 a3 1.9 tdi and for a few weeks now i have not had any turbo boost. Its like im driving a bus and is so slow it makes me want to weep. have replaced MAF, didnt fix it. Have replaced N75, didnt fix it. what other options do I have? thanks for any help. |
Just curious why do you say the turbos no kicking in? Do you have a boost gauge?
If you do does the gauge read in -ing at idle? Does it move at all when you press the gas pedal? Does it idle normal? Any vac leaks? Not a big time diesel mechanic. Just using my petrol expierience here |
No I havnt got a boost gauge. Basically I mean I floor the car in 2nd and no soot out back, no power and basically labours slowly up to speed with high revs. What is idling normal? And how can I check vac leaks? Desperate to fix, just been on a long drive and I can't believe the amount I pay for insurance for the speed I get. Thank you for the help.
Well get a boost gauge first and foremost. Vac leaks can be tested w/ smoke by feel or with a tester.
this is the same problem i am to facing and waiting for the solution. please guys help me.
Still no luck. Havnt had much chance to fiddle yet though. Will test vac pipes for leaks/blockages. Would a faulty N81 valve affect? I've heard blocked air filter may?
