[[Elim 2871R Dyno Result]]
Old Mar 18, 2006 | 09:52 PM
  #21
aaronamericahall's Avatar
Default RE: [[Elim 2871R Dyno Result]]
so arif what all do you have done to your car------- manifold, testpipe, injectors, inlet pipe, etc.???? I have the gt2871 kit at home but just waiting to get it installed and I'm just trying to see what I will need to get to be at least where your at on the dyno
Old Mar 18, 2006 | 09:59 PM
  #22
xx18quattroxx's Avatar
you wanna watch out with the whole turning the fuel press down, esp with your timing... leaning out a motor is like advancing the timing, in a backwards sideways kinda way... just make sure she doesn't knock.
What rpm are you at full boost?
Old Mar 18, 2006 | 10:02 PM
  #23
aRIf's Avatar
ORIGINAL: aaronamericahall
https://www.audiforums.com/MemberRid...Ride.asp?ID=90
Old Mar 18, 2006 | 10:29 PM
  #24
headshok2002's Avatar
290whp is great but that torque figure is dissapointing eh?
Old Mar 18, 2006 | 11:01 PM
  #25
aRIf's Avatar
ORIGINAL: headshok2002
yes. It is low dunno why.
Old Mar 18, 2006 | 11:42 PM
  #26
audiboy1618's Avatar
Nice Arif, 290awhp is nothing to mess around with.
You'd kill my s4...haha good work..you have about 85awhp on me.
Old Mar 18, 2006 | 11:47 PM
  #27
Jeff's Avatar
Zombie Defense Force
you should be happy wiht 290whp
Old Mar 18, 2006 | 11:49 PM
  #28
liquidxit2's Avatar
ORIGINAL: aRIf
ORIGINAL: liquidxit2
your timing should be a little higher then that. wow I didnt know you were running 44 psi in that case sell that turbo setup and get a new one. Im sorry if Im being rude but 44psi on an upgraded turbo shouldf put out a decent ammount of power. Over stock thats only 2.7 lbs of torque per psi. Feel free to bash and flame me and I wont mind.
yes 44.1 is fuel pressure not boost. Unitronic recommend to run 44.1 fuel pressure but mine is little higher than that, I think that's why I'm rich
hahaha ohhh thats changes everything
ORIGINAL: Jeff
better to run rich then lean
yes but too much fuel is bad as well. I think if he leaned it out a bit hed make more power.
So how much boost are you running? with timing at 0 Im thinking a little too much. Maybe turning down the boost may yeild tons of gains. I remeber on my dsm I would run negative timing (retarded timing to be correct) and would peak at -1 to 3 degrees and when I did some timkering and lowered boost abit my timing only retarded at the point of full throttle and I thus had a healty gain in timing through th rpm rang toping at 17 degrees before tdc. That lower boost setting yeilded me tops more power then the higher boost setting.
Old Mar 18, 2006 | 11:50 PM
  #29
Jeff's Avatar
o ya too much fuel is not good either but its better to run rich then lean idealy he wants to be running neither rich or lean but safer to run rich
Old Mar 18, 2006 | 11:53 PM
  #30
liquidxit2's Avatar
ORIGINAL: Jeff
yessum, I really wish I knew audis cause Id like to tinker with his cars fuel and boost and I bet there are some seriouse gains to be had.[8D]
