[Deleted]
Old Apr 10, 2003 | 06:40 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Apr 11, 2003 | 12:39 AM
BoostedA4's Avatar
Default APR and dealers
Just get it socketed, and before you go for service, switch it out for the stock unit. Socketing costs like $100 more, but you'll prob save in getting things fixed under warranty. Also other manufacturers have a remote switch that will change it back to the stock settings using a switch inside the car.</P>
Old Apr 11, 2003 | 02:08 AM
A4toZ's Avatar
APR has a lockout you can get so it won't be detected. Also - per warranty, if your problem is not a direct relation to your mod, they should fix it.</P>
In other words - if you play, be prepared to pay.</P>
Old Apr 11, 2003 | 02:23 PM
Default [Deleted]
[Deleted by Admins]
Old Apr 11, 2003 | 04:32 PM
A4toZ's Avatar
Depends on how much of an increase you go for. Neuspeeds, I beleive, is relatively low. As you go for more... you'll need some add-ons to assist with the power (BPV, intercoolers, exhaust, etc.)</P>
</P>
You just may want to do some research before you go into it. I suggest picking a brand you're comfortable with (and has a local distributor... just in case issues do arise) and then give them the "if - then" situations.</P>
Old May 14, 2003 | 07:56 PM
Default [Deleted]
[Deleted by Admins]
Deleted User
Feb 27, 2004 08:42 PM
Deleted User
Jan 27, 2004 12:58 AM
Deleted User
Oct 23, 2003 03:37 PM
Deleted User
Sep 22, 2003 09:08 AM
Deleted User
Sep 21, 2003 02:30 PM
