1.8T vs. S4
Old Apr 6, 2005 | 01:38 AM
  #41
audiboy1618's Avatar
Default RE: 1.8T vs. S4
Yeah, that dyno has been said not to be accurate.
Old Apr 6, 2005 | 01:42 AM
  #42
apg96's Avatar
i also found one of the s4 chipped
Old Apr 6, 2005 | 01:44 AM
  #43
apg96's Avatar
ORIGINAL: CheckMyVitals
sure ya have.
ab was just saying that you shouldn't be buying the supercharger 'cause it's rare, but because they make 300hp... and there's no lag.
but in things i read about the s4 is the turbo spools at 1800 RPM so if i never shifted when the RPM would be dropping below that i would have no lag right? (plz help never had a turbo car except i drove a wrx but that had some lag unless u slam it)
Old Apr 6, 2005 | 01:52 AM
  #44
When they say spool at 1800, yes the blades are turning, but not enough to throw u back in ur seat. Get a s/c. you will be glad u did it.
Old Apr 6, 2005 | 02:15 AM
  #45
apg96's Avatar
the only thing is that a s/c for my car is more than trading it in and buying a s4 and if i had a s/c then what? an exhaust and that about it for performance
Old Apr 6, 2005 | 02:22 AM
  #46
Theres alot more you can do, exhaust, intake,light wheels, carbon fiber hood, work on weight reduction,cams, cam gears,highflow cats, theres alot, just gota use ur brain.
Old Apr 6, 2005 | 02:24 AM
  #47
apg96's Avatar
yea, about the brain thing i dont like having to use it.
But i will have to think about that one.
Old Apr 6, 2005 | 02:27 AM
  #48
TomRitt's Avatar
Yea there is plenty of options with the supercharger. One misconception most ppl have is that both the supercharger as well as apr s4's graphs above are CRANK hp, wheel hp numbers are abour 22% less.
Old Apr 6, 2005 | 02:31 AM
  #49
apg96's Avatar
ORIGINAL: TomRitt
But they will still both decrese the same amount so it doesn't matter as long as both cars hp is at the crank.
Old Apr 6, 2005 | 02:47 AM
  #50
ImolaS4's Avatar
ORIGINAL: TomRitt
I was dissapointed with th numbers i saw from an s4 with k04's, 324 whp on pump and around 425 whp on race gas. I should be making those numbers soon with 2 less cylendars and 1 less turbo
Those are weak numbers for a KO4 modded S4. They should be closer to 340 at the wheel.
