1996 Audi A4 Intermittent Starting Problem Help!!
Old Apr 9, 2007 | 02:13 PM
new2me's Avatar
Default RE: 1996 Audi A4 Intermittent Starting Problem Help!!
It could be something stupid like a loose connection or the starter on its way out. But if the mechanic's cant get the car to do what your saying it does they cant diagnose it.
Old Apr 9, 2007 | 02:15 PM
sarah062381's Avatar
Ok, based on your definitions, the car is cranking but won't take the next step to cause the engine to run. Does that explain..?
Old Apr 9, 2007 | 02:27 PM
akielb's Avatar
ok - then its not the starter. I'm guessing that they have read the codes in the computer and that did not give them any help. ???? don't know what to tell you - bad coil pack? fuel delivery problem(fuel filter, fuel pump)?
Old Apr 9, 2007 | 02:32 PM
new2me's Avatar
Does it smell like raw gas when it wont start?
Fuel delievery could be an issue like really clogged injectors.
I would think the car should miss fire if it was a coil pack?
1 of the o2's
MAF & throttle body are dirty as a ****?
So many options here.
Old Apr 9, 2007 | 02:33 PM
The mechanic says it's either a problem of fuel delivery or absence of spark. However they can't tell until the car shows them the problem..... which may take weeks, or may happen tomorrow. This is one of the most frustrating problems...... anyone live in NC and want to buy a car?? :/
Old Apr 9, 2007 | 02:36 PM
Another thing.... after it has trouble starting, and it starts on the third try (or so), a big cloud of black smoke comes out of the exhaust system.
Old Apr 9, 2007 | 02:38 PM
new2me's Avatar
Spark!
Old Apr 9, 2007 | 02:50 PM
  #18
akielb's Avatar
have they replaced your spark plugs? - also have you told us if this is a 1.8t or a 2.8
Old Apr 9, 2007 | 03:03 PM
  #19
The spark plugs have not yet been replaced. It is a 2.8.
Old Apr 9, 2007 | 03:18 PM
  #20
akielb's Avatar
Get them replaced - always a good idea, and since you have owned it for awhile now I'm sure its ready for a new set. tell them to see if the plugs are fouled(very black) or if they see any other problems with them. Your mechanic should also be able to do a spark test to make sure all the cylinders are firing.
