19x8.5 w/ 32 offset on b5
235/35/19 will I rub? Mess up my control arms? Need answer asap, tried to search, but couldnt really find what I was looking for. |
RE: 19x8.5 w/ 32 offset on b5
Should be fine at the back. Good offset for the 8.5inch
Though the front might rub the inner guard on full lock |
I think 19s don't look good on a b5, just looks too big plus the fitment issues. 18s are better IMO
They will not rub.....18's look like sh!t on B5's and alot of people will tell you to not get 19's. Go 19 you'll be glad you did imo!
https://www.audiforums.com/upfiles/1...E2DA44916B.jpg |
If you lower it, it will rub. I had 18x8.5 with a 35 mm offset on my b5, and the wheels were flush with the fenders. I had to roll the fenders. So a 32 offset will be even worse.
ORIGINAL: flyinb501 If you lower it, it will rub. I had 18x8.5 with a 35 mm offset on my b5, and the wheels were flush with the fenders. I had to roll the fenders. So a 32 offset will be even worse. |
Front: 19x8.5 w/ 35 mm offset
Rear: 19x9.5 w/ 35 mm offset |
I just fit my 19x8.5 with 40 offset.. look huge on the car! (has lowered koni shocks and springs)
It looks like it need a lower bodykit big time now! Anyways, after fitting my 19's, i think flyinb is right.. with 32mm offset it will stick out and touch the fender with lowered suspension. My 40mm offset sit just inside the fender and dont rub. But with my 40mm offset, u get occasional rub on the shock body at the rear, and front toe joint. Beermod, have u lowered ur B5 yet? On bumps at high speed, the front tires seem to hit the upper toe join above the wheels and make that squeel noise. This happen to you? Any rub at the back? What offset and width wheel? Optimum specs for 19's though would be 19x8 with ET of 35 |
i agree 19's are the only way to go for a b5, and if it rubs have your fenders rolled......and you can get upgraded control arms fro Blauparts.com
