2001 A4 Quattro 1.8T Driver side headlamp removal!!
:Help!! Please --- Where are the nonobvious 2 (presumably) screws to get driver side Headlamp out?? I do have the T30 star bit for the obvious screws. Have spent huge amt of time trying to find info about where else the headlamp assembly is attached beside those obvious two screws. No illustrations , explanations anywhere and just can not see when look under hood myself. Thanks!!
There are the 2 obvious bolts on the top, and 1 more bolt that is behind the headlight and is very difficult to see. You will access it through the hole in the frame of the car next to the 2 bolts that secure the core support. I have attached a couple pictures for you.
QuattroBob
02-22-2011 12:47 PM
