A4 Audio system and SD cards
Hey guys, I'm new here.
I just ordered myself a 2007 A4 with a nav system, and I know that there are 2 slots for SD cards behind the screen. What I don't know is what format the system supports. I wanted to get the 4GB SDHC cards. Will those work? or do i have to settle for the regular 2GB cards?
Thanks
Thanks
check out www.navplus.us 4gb sd cards work, but not 8gb because its sdhc... make sure that the 4gb card you get isnt sdhc and it will work... this is the one im using and its fine.. just make sure to keep it under 512 files or else it will only find the 1st 512 files. also, dont use any wierd characters in the filenames (alphanumeric and '-' only... the rest might make the navi (rns-e) not detect the file)
http://software.palminfocenter.com/p...es.asp?id=7879
hmm, I was under the impression that 2GB was the limit for non-hc cards, and that all 4GB are hc due to memory addressing constraints...
edit: after checking navplus forum it seems that there are 4GB non-hc cards, however since you can only have 512 items on the card, 4GB cards are somewhat useless...
