A4 Automatic Trans Rear Seal....
Old Nov 11, 2007 | 08:20 AM
mimgq2's Avatar
Default A4 Automatic Trans Rear Seal....
Hello-
I changed my transmission oil last night and noticed my rear seal is leaking on my automatic. 2001 A4 1.8T. Didn't wan't to take to much time to evalutate the R&R of the tail shaft but was wondering if anyone has done this on their A4 and how difficult of a repair this is.
Thanks
Old Nov 11, 2007 | 08:57 PM
mimgq2's Avatar
Default RE: A4 Automatic Trans Rear Seal....
Ok , It appears to be an easy project, jack car, mark shaft , remove bolts, push shaft to the side, put 2 bolts in the flange, unbolt the t40 inner bolt. shaft should be removed. Now what is the part number for the seal??? 2001 a4, 1.8T auto.
Old Nov 11, 2007 | 09:22 PM
auditech79's Avatar
Yeah its an easy project, i think its a T45 torx for the center shaft bolt though. Call the dealer parts department and tell them you need the front prop shaft seal, There is a large o-ring on the tail housing of the tranny as well but i haven't really seen them leak.
Just pop out the seal with a small pry bar or screwdriver, lube up the new one and lightly tap it back and forth until its flush with the housing.
Billdog350
Nov 11, 2011 10:23 AM
virtualelvis
Jul 20, 2009 10:56 PM
mimgq2
Mar 11, 2008 11:11 PM
newblueA4
Sep 24, 2007 11:34 PM
mr2turbo81
Jul 28, 2007 11:41 AM
