a4 recalls for coil/ignition
hi, </P> anybody have any details on the recall audi/vw did for the coil and ignition problems? how can i find out if a particular A4 is recalled or not.</P> |
Call the dealer and have your VIN number handy.
MY firend had that problem with her 2001 A4 and they replaced the coil and now it works great <edited><editID>active1331</editID><editDate>38089.715</editDate></edited>
yeah I think 2001 and 2000 had the coil recall
what is it with the ignition that is being recalled? Sometimes I have the problem of turning it on and it won't start, so I have to do it againfor it to work
its the ignition coilpacks that were recalled. If you had a bad one you would know it when your car was running.
You might have a bad temp sensor if your car has trouble starting. Do you have to keep cranking it? |
no Ill try to turn the engine on, but instead everything else will turn on...radio, A/C, then I i turn back the key and try it again and it the engine will start.</P> |
so the car makes no attempt to crank over on the first try??
