A4B5 rear diff; compatability? LSD?
First off, my 99.5 A4 wagon does not have an LSD rear differential. I'm a bit peeved by this because I had been told all along that the rear was limited slip.
Back on subject... I was getting noise from in back and found one of the rearoutput shafts to be loose. The issue is a simple bearing, nothing special. I got the thing taken compltely apart and discover that I have a simple differential back there! No limited slip. This explains why I couldn't get moving when I had two wheels on ice a few months ago. So, here are my options: 1. Rebuild current diff and get an lsd to go in it. I don't know where to start for this and would rather do option 2. 2. Get a completerear diff, housing and all,from another A4/(S4?/A6?) which is compatible. Hopefully, one with LSD. I do not know whatcan be swapped in,so I started this thread. Specifications: 1999.9 A4, 1.8t,quattro, 5spd, avant Differential Code = DAJ Differential ratio = 3.889 |
RE: A4B5 rear diff; compatability? LSD?
I think the a8 rear diff is limited slip and there is a thread on audizine about it.. look it up over there.. or if i come across it ill post up a link
stasis rear diff :D
| All times are GMT -4. The time now is 06:48 AM. |
