RE: About to Change CVT Fluid
I guess it'll make more sense as I do it, it just seems weird that I'm filling the tranny from the bottom... seems upside down. :-)
ORIGINAL: avant80@2.6 the CVT fluid should come in a 1ltr container which has a long tube in the cap but some don't so you need a container to pump the fluid in ( ATF fluid containers generally have this feature ) and worth hanging onto an used container, only other way to get it in there is via a long tube with a funnel on it then put the tube into the filler on the tranny and fill till it overflows then its done put the bolt back in and off you go, the break bleeding system come with directions and its a one man kit you want |
ORIGINAL: AudiTech04 You forgot to add that the tranny fluid temp needs to be between 35 and 45`C to be at the correct level when it starts dripping out |
Dealer should have some
Yea, gonna call them tomorrow
$15/liter from the dealer. not bad. I'll pick some up Thursday.
ORIGINAL: AudiTech04 ORIGINAL: avant80@2.6 the CVT fluid should come in a 1ltr container which has a long tube in the cap but some don't so you need a container to pump the fluid in ( ATF fluid containers generally have this feature ) and worth hanging onto an used container, only other way to get it in there is via a long tube with a funnel on it then put the tube into the filler on the tranny and fill till it overflows then its done put the bolt back in and off you go, the break bleeding system come with directions and its a one man kit you want |
Okay one last thing -- according to the manual the tranny holds 9.0L of fluid, but when you change it you only need 2.7L. That doesn't seem very effective.
