ABS problem?
Old Feb 18, 2004 | 10:06 AM
Audi1978's Avatar
Default ABS problem?
Hi chaps, i've just bought my first Audi A4 and i'm well pleased. Its the 1.8 SE model. I have a problem with it...when i pull up just before the car stops i can feel the brake pedal vibrate (like the abs is activated). It is fine when braking from high speeds etc but always does it just before the car finally stops.</P>
Is this a common problem and will it cost me a lot to fix?</P>
Cheers, Tom</P>
Old Mar 14, 2004 | 07:20 PM
eddy4a2297's Avatar
Same thing happening to me since I had two new lower suspension arms fitted last week. If you have found out the cause of the problem please let me know. I will post another message if I find the solution.</P>
Old Apr 19, 2005 | 07:12 AM
bgmail's Avatar
Default RE: ABS problem?
Ive had my tracking control arm replaced recently under a recall, and as soon as I left the garage I get this very same thing... Brakepedal judders and makes a strange noise right before i come to a complete stop. Can anyone shed some light on it?
Old Apr 19, 2005 | 10:29 AM
TomRitt's Avatar
I've hard of the brake pad coming off the backing? Maybe check to make sure all the pads are seated properly. Thats all I can think of although I have heard of this problem before
Old Apr 19, 2005 | 12:59 PM
hakes's Avatar
Could be your wheel speed sensors are dirty, not seated properly, or malfunctioning. I bet they just need to be adjusted/cleaned. Good luck!
Old Apr 19, 2005 | 01:28 PM
BFlan2001's Avatar
your problem is your speed sensor. there is one on each axle....most likely it just wanted reinstalled correctly, if you have a lift you can probably fix it yourself.....or you can take it back to the shop and have them do it. if they damaged it, a new one is about 140 bucks from ecstuning iirc....
Old Apr 19, 2005 | 05:49 PM
OWDI's Avatar
Actually guys your problem is your ABS sensor. I had the Exact same problem and took it to AUDI themselves to diagnose. After spending $400 CANADIAN ( i know i got ripped ) the problem got fixed. You know its your ABS sensor when your stoping at a stop sign and your ABS activates under light braking.
Hope that helps
Old Apr 19, 2005 | 11:03 PM
BFlan2001's Avatar
same thing, it's the abs sensor that monitors the speed of your axles....i guess i should've said the speed sensor for the abs system
Old Apr 19, 2005 | 11:10 PM
skidplatexa4's Avatar
sounds like the speed sensor I used to have that problem, but when doing a wheel bearing I had to beat the old sensor off and now theres a nice new one in there so it's like I killed 2 birds in one stone
Old Apr 19, 2005 | 11:30 PM
BFlan2001's Avatar
let me clarify here, the speed sensor and the abs sensor that we're all referring to are the same piece.....
