AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   ABS problem? (https://www.audiforums.com/forum/audi-a4-8/abs-problem-1004/)
Audi1978 Feb 18, 2004 10:06 AM
ABS problem?
Hi chaps, i've just bought my first Audi A4 and i'm well pleased. Its the 1.8 SE model. I have a problem with it...when i pull up just before the car stops i can feel the brake pedal vibrate (like the abs is activated). It is fine when braking from high speeds etc but always does it just before the car finally stops.</P>
Is this a common problem and will it cost me a lot to fix?</P>
Cheers, Tom</P>
eddy4a2297 Mar 14, 2004 07:20 PM
ABS problem?
Same thing happening to me since I had two new lower suspension arms fitted last week. If you have found out the cause of the problem please let me know. I will post another message if I find the solution.</P>
bgmail Apr 19, 2005 07:12 AM
RE: ABS problem?
Ive had my tracking control arm replaced recently under a recall, and as soon as I left the garage I get this very same thing... Brakepedal judders and makes a strange noise right before i come to a complete stop. Can anyone shed some light on it?
TomRitt Apr 19, 2005 10:29 AM
RE: ABS problem?
I've hard of the brake pad coming off the backing? Maybe check to make sure all the pads are seated properly. Thats all I can think of although I have heard of this problem before
hakes Apr 19, 2005 12:59 PM
RE: ABS problem?
Could be your wheel speed sensors are dirty, not seated properly, or malfunctioning. I bet they just need to be adjusted/cleaned. Good luck!
BFlan2001 Apr 19, 2005 01:28 PM
RE: ABS problem?
your problem is your speed sensor. there is one on each axle....most likely it just wanted reinstalled correctly, if you have a lift you can probably fix it yourself.....or you can take it back to the shop and have them do it. if they damaged it, a new one is about 140 bucks from ecstuning iirc....
OWDI Apr 19, 2005 05:49 PM
RE: ABS problem?
Actually guys your problem is your ABS sensor. I had the Exact same problem and took it to AUDI themselves to diagnose. After spending $400 CANADIAN ( i know i got ripped ) the problem got fixed. You know its your ABS sensor when your stoping at a stop sign and your ABS activates under light braking.
Hope that helps
BFlan2001 Apr 19, 2005 11:03 PM
RE: ABS problem?
same thing, it's the abs sensor that monitors the speed of your axles....i guess i should've said the speed sensor for the abs system
skidplatexa4 Apr 19, 2005 11:10 PM
RE: ABS problem?
sounds like the speed sensor I used to have that problem, but when doing a wheel bearing I had to beat the old sensor off and now theres a nice new one in there so it's like I killed 2 birds in one stone:):D
BFlan2001 Apr 19, 2005 11:30 PM
RE: ABS problem?
let me clarify here, the speed sensor and the abs sensor that we're all referring to are the same piece.....
